Searching for 6.0.1
I’ve found Notes Client/Designer 6.0 to 6.0.1 incremental installer: and ADMINISTRATOR?
I’ve only found Domino 6.0.1 full (NOT the incremental installer): will it be available later?
If I install 6.0.1 do I also need to upgrade the language packages (and where/when are they available)?
Subject: Administrator?
Yes, it doesn’t say it contains the administration client, does it - just the client and designer.
Just installing that kit now. If it doesn’t upgrade the administrator I will post again and say so.
I got the incremental server install here yesterday.
http://www14.software.ibm.com/webapp/download/search.jsp?q=&cat=&pf=&k=&dt=&go=y&rs=ESD-DMNTSRVRi&S_TACT=&S_CMP=&sb=r
Ain’t there now - just the client kits (in the Domino server downloads section!).
