Search Problem
Hi All,
I am trying to set selection formula on a view. There is field which is richtext and in it there is running text. Now I want to select all the document which found in the richtext box. Let says in richtext there is a sentence :
"which is richtext and in it there is running text. Now I want to select all the document which found in the richtext box. Let "
Now if it would be text field then in selection formula we can use select form = “ABC” & @contains(txtfield1;“found”) then it return document.
But my problem is these sentence contain in richtext field.
So pls suggest me how could i use selection formula to achive this task
pls help it an urgent for me.
I will be very thank ful to u if somebody help me.
Thanks & Regards,
Vikas K Sinha
Subject: Search Problem
Create a computed text field with a formula @text(YourRichTextField) and then apply this new field in your view selection formula. The only problem is if it is a production system then you’ll need to backflush all the documents with this new text item.
HTH
Sai
Subject: RE: Search Problem
Or you can use @Abstract, if this is suitable, in your select formula.
Cheers,
Adrian
