Search engine unable to search for numbers?
the default search engine in domino designer seems like its unable to search for numbers, return 0 results… why?
Subject: search engine unable to search for numbers?
Yes, that is correct. It’s been a long time since I’ve played with a full text index configuration (version 4) so this maybe a little out of date. To include numbers you use to have to update the stop word file to indicate you wanted include numbers.
This arcile seems to indicate the stop word files are no longer used.
Subject: RE: search engine unable to search for numbers?
erm, i still don’t understand how to do it…
another example
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/792a89da12db374185257434004d14c7?OpenDocument
