Hi,I have an embedded view in a form. The view contents for a particular field will generally be more. Eg: Comments field.
This field is the last column in the view.
Since its more I want to display the contents by showing a scrollbar for that particular document row.
Already my embedded view has got another scrollbar outside which will expand the view’s documents in case of more number of documents to be displayed.
So hope you would have got a picture of my requirement.
Can anyone please let me know if I can enable scrollbar for that particular document alone if the content of the Comments field is more. (inside the embedded view) ???
Thanx in adv !!
Subject: Scrollbars for columns contents inside an embedded view
Instead of giving scroll bar to the particular document data, you can give scroll to the comments data for every column.
the scroll will come whenever the data is more in comments column.
see the below pseudo code of the table:
| A |
B |
C |
Comments |
| A |
B |
C |
ssssssssssssssss
sdfsdafjkhasljdfhskdjafsdfashdkfjhsdjkfhsjkdshfsakdjfhkasjdfhkasdf
asdfhsadkfhkasdjfhsjadf
sdafhasdjfhaskdfhsad
sadfhaskdjfhkasjdhf |
Thanks,
Sreedhar
Subject: RE: Scrollbars for columns contents inside an embedded view
Sreedhar,
Can you please let me know how to use the same code in a view (here: embedded view ) ?
Thanks for your repsonse…
May i know where you are going to use because this will work in web only.
Sreedhar
nope this is not a web application.
I want to use it in Client .
