Scheduled Replication not taking place
I have a replication schedule set up for my mail database and one other database. Manual replication works fine, but come the scheduled time for replication and nothing happens, even if I have new mail waiting. After I replicate manually, the schedule on the top right of the page says the next replication is schedule for ten minutes from now–as it should be. When the appropriate time for replication comes, nothing happens, but the schedule on the top right says the next replication is at one week from now. Odd. Any ideas?
Subject: Are the DBs checked “on”.
Do the DBs have check marks on the first column?
Subject: RE: Are the DBs checked “on”.
yes. everything obvious is as it should be. unless i’m overlooking something obvious–which i may be doing. but not that one. :wink:
Only time I’ve ever seen the “doesn’t replicate, and says the next scheduled time is a week from now” is when the location document’s interval doesn’t have any days in “Days of week:” field.
that might be it. that field was indeed left blank by the admin who set up notes for me. i just filled in all the days of the week, we’ll see what happens in 10 minutes. Thanks!!
Subject: I should also note…
outgoing mail is set to be delivered immediately upon pressing “send”–and it is.
