Scheduled agents not running
I write this code for tracking documents. But when I run manually, it is successfully run. But when I schedule to run the agent, there was an error “Agent execution time limit exceed”.
This is my code:
Sub Initialize
Print "Start"
Dim curdb As NotesDatabase
Dim setup_doc As NotesDocument
Dim setup_db As NotesDatabase
Dim setup_View As NotesView
Dim tracking_doc As NotesDocument
Dim tracking_db As NotesDatabase
Dim tracking_View As NotesView
Dim rtitem As NotesRichTextItem
Dim gacs_doc As NotesDocument
Dim gacs_db As NotesDatabase
Dim gacs_View As NotesView
Dim gacs_dc As NotesDocumentCollection
Dim cnName As NotesName
Dim slcted_doc As NotesDocument
Dim slcted_db As NotesDatabase
Dim slcted_View As NotesView
Dim slcted_dc As NotesDocumentCollection
Dim keyString(1) As String
Set curdb = session.CurrentDatabase
Set gacs_db = New NotesDatabase("SunwebA1/S/Sunway", "Ghr\ApprCtrl.nsf")
Set setup_View = curdb.GetView("svAppsSetup")
'Set gacs_View = gacs_db.GetView("MainICNameTrackingStaff")
'Set gacs_doc = gacs_View.Getfirstdocument
Set setup_doc = setup_View.GetFirstDocument
recNo = 0
While Not setup_doc Is Nothing
	dbServer = setup_doc.GetItemValue("dbServer")(0)
	dbPath = setup_doc.GetItemValue("dbPath")(0)
	Set slcted_db = session.GetDatabase(dbServer, dbPath, False )
	Set slcted_View = slcted_db.GetView(setup_doc.GetItemValue("ViewName")(0))
	Forall sStatus In setup_doc.Status
		While Not gacs_doc Is Nothing
			recNo = recNo + 1
			sName = gacs_doc.empname(0)
			Set cnName = New NotesName(sName)
			'Print Str(recNo)
			keyString(0) = sStatus
			keyString(1) = cnName.Common
			Set slcted_dc = slcted_View.GetAllDocumentsByKey(keyString)
			Set slcted_doc = slcted_dc.GetFirstDocument
			'Print setup_doc.dbpath(0) + " - " + sStatus + " - " + setup_doc.FormName(0) +  " - " +setup_doc.FormApproverNm(0) +  " - " + cnName.Common + " - "  + Cstr(slcted_dc.count)
			While Not (slcted_doc Is Nothing)
				'If Not setup_doc Is Nothing Then
				'Print  slcted_doc.GetItemValue(setup_doc.GetItemValue("FormApproverNm")(0))(0) + "=" + cnName.Common
				If slcted_doc.GetItemValue(setup_doc.GetItemValue("FormApproverNm")(0))(0) = cnName.Common Then
					Set tracking_doc = New NotesDocument(curdb)
					tracking_doc.Form = "dfApprover"
					tracking_doc.appsTitle = setup_doc.AppsTitle
					tracking_doc.txtDocStatus = sStatus
					tracking_doc.txtFormNm = setup_doc.FormName
					tracking_doc.txtCategory = setup_doc.slcCategory
					tracking_doc.dbServer = setup_doc.dbServer
					tracking_doc.dbPath = setup_doc.dbPath
					tracking_doc.docCat = setup_doc.slcCategory
					tracking_doc.docType = setup_doc.slcType
					tracking_doc.BU = setup_doc.slcBUGrp
					tracking_doc.txtStaffName = cnName.Common
					tracking_doc.ViewName = setup_doc.GetItemValue("ViewName")(0)
					tracking_doc.StsFieldNm = setup_doc.GetItemValue("FormFieldStatusNm")(0)
					Set rtitem = tracking_doc.CreateRichTextItem ("DocLink")
					Call rtitem.AppendDocLink (slcted_doc, "" )
					Call tracking_doc.Save(True, False)
				Set slcted_doc  = slcted_dc.GetNextDocument(slcted_doc )
			Wend
			Set gacs_doc = gacs_View.GetNextDocument(gacs_doc )
			'Set gacs_doc = gacs_View.GetNthDocument(gacs_doc )
		Wend
		Set setup_doc = setup_View.GetNextDocument(setup_doc )
		'Set setup_doc = setup_View.GetNthDocument(setup_doc )
	End Forall
Wend
Print "Completed"
Please helppp
Subject: Time
So how long does it take to run the agent?What is the server agent time limit set to?
The error typically means that it’s taking too long for the agent to run. You can:
Find a way to make the agent take less time to run.
Schedule the agent to run when the server time allowed is longer (it’s not uncommon for time allowed for LS agents is different at different times of the day)
Get your admin to extend the time so the agent doesn’t time out.
