Schedule Agent Problem..pls help
Dear all,this agent runs on a view and sends mails for perticular users. My problem is it always runs for a single record. And sometimes it doesn’t run at all…even if i run it on manual. Pleas help me
Regards
shana
Sub Initialize
Dim Currdb As NotesDatabase
Dim CurrDoc As NotesDocument
Dim view As NotesView
Dim doc As NotesDocument
Dim Manager As String
Set Currdb = session.CurrentDatabase
Set CurrDoc = New NotesDocument(Currdb)
Set view = Currdb.GetView( "SerAgreeAgt_View" )
	'===========Update DB2========================
Dim con As New ODBCConnection
Dim qry As New ODBCQuery
Dim rs As New ODBCResultSet
Dim userName As String
Dim password As String
userName="DOMUSR"
password ="DOMPASS"
’ Call con.ConnectTo(“C601627B”, userName, password)
’ Set qry.Connection = con
’ Set rs.Query = qry
Dim Edate,Rdate As Variant
While Not (doc Is Nothing)
	Call con.ConnectTo("C601627B", userName, password)
	Set rs.Query = qry
	Rdate = doc.renNotification(0)
	Edate =doc.endDate(0)
	'Dim STA As String
	If Rdate=Today() Then
		MailTo = doc.perRenewal(0)
		subject = "Pending Maintenance Agreement"
		doc.Status="Pending"
		'STA=doc.Status(0)
		Call OnApproval(doc,MailTo,subject,"MainAgreement")
	Elseif Edate =Today() Then
		'MailTo = rs.Approver(0)
		'MailCC=rs.Approver(0)
		subject = "Pending Overdue Maintenance Agreement"
		doc.Status="Pending Overdue"
	'	STA=doc.Status(0)
	Manager=Cstr(doc.Approver(0))
	doc.FutureApp= Cstr(MailTo & "-  Action - Renew")
	doc.FutureApp_1= Cstr(Manager & "-  Action - Authorise")
	doc.FutureApp_2=""
	doc.HCurrAppNo=4
	Dim ANo As Variant
	ANo=doc.agNo(0)
	qry.SQL="UPDATE WINAPPS.KLMAINT_AGREEMENT set Status_Code='" & doc.Status(0) & "' WHERE Agreement_No= '" & ANo & "' "
’ qry.SQL="UPDATE WINAPPS.KLMAINT_AGREEMENT set Status_Code=‘Pending’ WHERE Agreement_No= ‘00004’ "
	rs.Execute
	con.Disconnect
	Call doc.Save (False,True)
	Set doc = view.GetNextDocument(doc)
Wend
'===========End DB2 Update====================
Subject: schedule Agent Problem…pls help
Could it be, that the modifications you make to the document force it to disappear from the view? Try to set view.AutoUpdate = False
before your loop.
Also, I’d like to know why you moved the connection stuff inside the loop.
Subject: RE: schedule Agent Problem…pls help
Thanks a lot…now the loop works…but it does’t update DB2 file. When i hardcode the Where clause it works…
A small tip to begin with: LotusScript knows 3 different string delimiters:double quotes “stringOne”
pipes |stringTwo|
curly braces {string three}
There are tiny (but sometimes important) differences, like a string delimited by pipes can contain literal line breaks, but generally they work the same. When writing stuff like SQL statements or @Formula macros to evaluate, simply pick one of the three choices, that doesn’t interfere with the string you put together.
Your SQL statement would be a lot easier to read, if you use pipes instead of quotes, because of the single quotes in your query.
If it works with the hardcoded where clause, obviously the variable ANo does not contain a correct value. What kind of field is agNo? For your code to work, it must probably not be a number field, because DB2 will most probably want to be fed the number with leading zeros. Also, you shouldn’t declare ANo as Variant, but rather as the datatype fitting the job best.
Use the debugger to check the status of ANo before building the query and most probably you’ll see what’s wrong.
Thanks a lot…i’ll try that out…
