Saving of Attachment Problem
Hi AllI am admin, when im attaching files in web. It saves all files but when some one else trying to attach more than one files then only last file which he attaching is saved & rest of all not saved. The agent which im writing is as follows :
Sub Initialize
Dim sess As New NotesSession
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim rtitem As NotesRichTextItem
Dim object As NotesEmbeddedObject
Set db = sess.CurrentDatabase
Set doc = sess.DocumentContext
Set rtitem = New NotesRichTextItem( doc, "rich" )
Forall i In doc.attach
	Set object = rtitem.EmbedObject(EMBED_ATTACHMENT, "", i, "attach" )
End Forall
Sanjay Prasad
Subject: Saving of Attachment Problem
Dear Sanjay,
Ur code works fine , u have to dump all the attachment one by one into another field , so that it could be avialable while document will refresh
RIshi
Subject: RE: Saving of Attachment Problem
Dear Rishi & All,I am doing so one by one in to another field, but in my machine it is working fine cos im admin, in other machine it saves only last attachment.
Sanjay Prasad
