Save Problem
I have created one form. In that “Save” button with the value as @command([Filesave]) and “Close” button with the value as @command([FileClosewindow]) and “SaveOptions” reserved field also there.The problem is that i filled all the values and click on “Save” button, the document is saved. when i click on cross mark to close the window, it’s asking “Do u want save ur changes” again.
If i click on “close” button it’s not asking.
What could be the problem? Anybody can help me?
Subject: Save Problem
To do a save and close, Don’t use a saveoptions field. Do this:
@if(@command([FileSave]);@command([FileCloseWindow]);“”)
@command([FileSave]) only returns TRUE if all the validations pass.
A cancel button wuold be:
FIELD SaveOptions:=“0”
Line 1 here means “Don’t prompt to save”
Line 2 means “close”
but because you don’t save, the SaveOptions field is never actually added to the document!
Subject: RE: Save Problem
Please use the below code…
@Command([FileSave]);
@Command([CloseWindow]); // dont use fileclosewindow
Regards
VK
