Hello, i’ll try to speak english.I have a main tabbed xpageA with it datasource DS1(create document).
Into xpageA, have included xpageB(tab3) and xpageC(not in a tab).
Into xpageB, have included xpageD.
xpageB with it datasource DS2(create document).
xpageC with it datasource DS3(create document).
xpageD with it datasource DS4(create document).
I create a new document.
When i click the save button, positioned into de tab1, i have no problems…
But when i change to tab 3, and click the save button, i get the documento multiplied by 4(3 save conflicts documents documents)
I think i have a problem with doing datasources.
somebody help me?
Diego
Subject: A workaround
Hi Diego,
I don’t have the answer as to why, but I can provide a workaround.
You can set the concurrency of the datasource to force an update, therefore preventing the replication/save conflicts.
On each of the datasources you are having the issues with select:
- All Properties->data->data->SourceName->concurrencyMode
and select “Force” from the dropdown list of choices.
Hope this helps,
-John
Subject: It worked but i don’t understand…
John, thanks you very much for that information!!! i will try it too…
But, some hours ago, all started to work fine.
I found a diference between tab1, tab2 and tabs 3, 4 y 5.
The problem is when i click tab3, tab4 or tab5, and save the document. Tab1 and tab2 all’s right.
The diference was that in tab1 and tab2 i have editBoxes with their data link.
But tabs 3, 4 and 5, are empty.
I put an editbox with their datasource in each tab,and it fixed it.
I don’t understand why, but it work. I don’t get more save conflicts.
Diego
PD: now, i will try your information too.
Subject: That’s that tabbed panel issue…
See http://www-10.lotus.com/ldd/nd85forum.nsf/DateAllThreadedWeb/4dc26fcfd79500f4852575750052e3c9?OpenDocument
The good news is that we have a fix for this. It should be in the 8.5 FixPack1 (June) and it will be in 8.5.1 (Q3).
But if you need a fix for this sooner you’ll need to log a PMR with support.
Regards,
Paul.
paul_hannan@ie.ibm.com
Subject: Thanks
Thank you very much Paul.I forwarded to my boss…
Diego
