Sametime window problem
At my company we got a HCL Notes 11.
Every time when I launch HCL Notes 11 clinent I got in a separate window a sametime chat window.
Is there any way to disable it turn of?
Best regards
All the customers are asking for it but it is not possible at this moment unless you close all the chats before closing Notes client: this should work.
thank you for a quick reply.
Closing all the chats before closing Notes client: not working.
I noticed that sametime will not close until all contact are listed.
If y do that before it, sametime will open again :D
Does it reopen chats that you have explicitly closed?
When I close all my history chats I get empty window, i'v added a screenshot.
Hello,
to close conversation you need to press small "X" on left side (not just close window):
This will prevent chat windows from opening during Notes restart
What works for me is pressing Escape while in the chat message entry area at the bottom, as many times as necessary to close the main window.
Hi Marcin,
There is a parameter that you can use to control the loading behavior which should be added to the plugin_customization.ini.
This property is used to control the visibility of the chat window while loading. When enabled, the chat window will NOT be visible until all the chats are loaded.
com.ibm.collaboration.realtime.chatwindow/lazyLoadingPanel=true
Please let us know if this is helpful.
