Sametime Integration with Notes 6.5 M2 Client problem - Solved
After installing R6.5 Milestone 2 Beta today I found that I was not able to log on to our Sametime server. The Sametime client is working perfectly, but the same connectivity settings entered in the Notes location document won´t work. I believe this is because the client tries to connect using my full Notes user name, whereas the Sametime server expects only the common name (looking for it in an LDAP directory on another Domino server).Can anybody tell me how to make this work?
Solution:
The NOTES.INI variable IMUserName did it.
