Running both R6 and R8 simultaneously
Is it possible to use both R6 and R8 clients at the same time? If yes, Please tell me if any settings has to be changed.
Regards,
Saranya
Subject: Yes, you can.
Rename your Notes 6 client.
Install Notes 8 to a new folder.
Run Notes 8 using the typical shortcut.
Change your Notes 6 shortcut to point to nlnotes.exe, and start it after Notes 8.
Subject: Watch your registry settings !
I have dual 6 & 8 client, designer, admin clients on my machine. You need to make sure that the install directories for 6 are switched on your machin and that the regedit for them points there too. Otherwise, you will see contention.
See IBM doc, GI11-7965, Ch 5, page 163 for details.
Subject: works perfectly!
Yes it worked perfectly! Thanks for your help!!
Regards,
Saranya
