RTItem: Using JavaScript Control not work
Dear All,i have an 8.5.1 domino server.
So i have created a simple form with a RichTextItem called Body and set the Web Access display as “RTItem: Using JavaScript Control”.
But when i open the form on web (IE or Firefox) not work. The RtItem as showed as a simple TextArea item.
There are some other options to set on form or on server in order to use the new option display option Using JavaScript Control ?
thank you
D.
Subject: any suggestions ?
up ! can you help me or any suggestions ?
