whenever i try to open a particular database i get an error msg
“RRV Bucket is corrupt”
this database is very important and i dont hane any replica of it.
Need urgent help to resolve this error
Thanks in advance.
Thanks in advance.
Subject: You should try to compact and fixup the database
This is probably a serious problem with your database. Do a quick search on “RRV” in this forum to see that this error do occur from time to time. Also do a quick search on “compact”, “fixup” and “updall” to see how to use these commands on the server (or locally if you do some installation tricks) in order to save your database. Good luck …
