Routing low prioriry
Hi !!!I’m using low priority by size to route big mails by night. This works both for incoming and outgoing mail. When want to route internal mail manually, I use route ServerName at the consola.
I trying to make a program document to route each hour but it doesn’t work. I’m using nrouter.exe, it’s correct ?
Thanks !!!
Subject: Routing low prioriry
Try “nserver -c route servername”
Domino comes with CONNECTION DOCUMENTS for this exact need. You don’t need a program document.Just setup a connection document, thats what they are there for. Setup one for each priority if you like.
Subject: RE: Routing low prioriry
Hi Mike !!
Also I have this documents, but low priority waits until night or until I write at console route * or route ServerName.
Any help ?
Maybe it’s too late… anywayplace
server -c “route ServerAbbreviatedName”
in program document
