Subject: Roaming enablement
I tried that a couple of times, but didn’t help.I got the notification that I was no longer enbled for roaming, tried to roam again, no success.
This is what I did now :
I created a new mailfile on the server and have put this new mailfile in my person doc in the nab.
Restarted my client, and I got immediately the pop-up if I wanted to upgrade to roaming user.
Let the complete admin process finishing until the roaming mark in the nab was there again.
Set my original mail file back into the person record.
So, the blocking factor should have been some flag or setting in my original mailfile.
When roaming setup was ok, the debug file looked as follows :
notesroaming_BELEU-89LL64J_2009_11_03@15_09_07.txt
03/11/2009 15:09:07.21 [1204:0002-1680] NEMInit> Calling NEMCheckPreviousInstance
03/11/2009 15:09:07.21 [1204:0002-1680] NEMInit> Setting Current Core Process Id to shared memory BLK_WCT_PID [4612]
03/11/2009 15:09:07.42 [1204:0002-1680] WM_DESK_INIT> Calling NEMCheckPreviousInstance
03/11/2009 15:09:07.44 [1204:0002-1680] DeskClientOpenInt> Calling CreateProgramRCP pszRCPCmdLine[/authenticate ] bDeskProvisioningRestart [0]
03/11/2009 15:09:07.44 [1204:0002-1680] DeskClientOpenInt> Executed CreateProgramRCP
03/11/2009 15:09:09.83 [11E4:0002-1098] InitGlobalProcessInfo> PID [4580]!= [0]
Preseting path to roaming lock db to CN=BELEUMAIL02/O=VWRI!!mail\lsteenho
Entering GetUpgradeLock()
Using Mail file as lock db
Using preset value CN=BELEUMAIL02/O=VWRI!!mail\lsteenho, as the mail file path
Path to the lock DB = CN=BELEUMAIL02/O=VWRI!!mail\lsteenho
Creating roaming lock document
Creating profile note for lock
Saving profile note
03/11/2009 15:09:35 Entering CheckIfUpgradeLockShouldBeReleased()
03/11/2009 15:09:35 Exiting CheckIfUpgradeLockShouldBeReleased()
03/11/2009 15:09:36 Dynamic Client Configuration started
03/11/2009 15:09:36 Initializing Dynamic Client Configuration
03/11/2009 15:09:36 Dynamic Client Configuration updating policy information
03/11/2009 15:09:36 Dynamic Client Configuration updating location information
03/11/2009 15:09:36 Dynamic Client Configuration shutdown
enter upgradenab
enter getroamingusernote
error on openprofilenote 1028
error on findbyname 1028
GetroamingNote returned 404
Idinnab 0
Setidinnbab returned 0
enter upgradenab
03/11/2009 15:10:58 Event Monitor started
Config(): Item not present:ProbPlacementThreshold
03/11/2009 15:11:23 The ACL in database CN=BELEUMAIL02/O=VWRI!!roaming\SteenhouwerLuc\names.nsf has been changed by names.nsf.
03/11/2009 15:11:25 The ACL in database CN=BELEUMAIL02/O=VWRI!!roaming\SteenhouwerLuc\bookmark.nsf has been changed by bookmark.nsf.
03/11/2009 15:11:28 The ACL in database CN=BELEUMAIL02/O=VWRI!!roaming\SteenhouwerLuc\journal.nsf has been changed by journal.nsf.
03/11/2009 15:11:28 The ACL in database CN=BELEUMAIL02/O=VWRI!!roaming\SteenhouwerLuc\roamingdata.nsf has been changed by roamingdata.nsf.
03/11/2009 15:11:28 The ACL in database CN=BELEUMAIL02/O=VWRI!!roaming\SteenhouwerLuc\localfeedcontent.nsf has been changed by localfeedcontent.nsf.
03/11/2009 15:28:06 Event Monitor shutdown
