In one of my forms I have the follwing formula in the PostModeChange event:
des := @Right(PartDesc;@Length(PartDesc) - 10);
@If(Status = “Approved” & ArchiveFlag = 0; “”; @Return(“”));
@If(PartStatus = “Inactive” ; @SetField(“PartStatus”;“Active”) : @SetField(“PartDesc”;des) ; “”);
@SetField(“Status”; “Modified”);
@SetField(“PDLSend”; “”);
@SetField(“PurchSend”; “”);
@SetField(“DisplayStatus”; “Modified”);
Now when a form is in the Approved state it will change to the Modified state if it has not been archvived. This works great if you do a double click to open the form or if you use the Edit button with the @command([EditDocument];1). However, yesterday it started not working if a user does a simple right click on the document and selects Edit.
Does anyone know how to fix this?
Thank in Advance,
Teri
