Hi.I have a database Form which contains a RichText Field called ‘ChemFormula’.
I want to be able to extract the contents of this field, edit it, and apply different formatting to different parts of it.
I’m a beginner as far as RichText Fields are concerned, and I’m having difficulty just setting up a basic template to deal with this.
The code I’ve written below gives me the error ‘Object variable not set’ for the Call statement near the end.
Any help with this problem would be great.
Thanks.
Sub Click(Source As Button)
Dim uidoc As NotesUIDocument
Dim doc As NotesDocument
Dim richStyle As NotesRichTextStyle
Dim molForm As Variant
Set doc = uidoc.Document
Set richStyle = session.CreateRichTextStyle
Set doc.ChemFormula = New NotesRichTextItem(doc, "Field")
richStyle.Effects= EFFECTS_SUBSCRIPT
Call doc.ChemFormula.AppendStyle(richStyle)
molForm = doc.getitemvalue("ChemFormula")(0)
Msgbox "Molecular Formula = " & molForm
Thanks for your help, John.But I still can’t get it to work.
Just to re-cap in a bit more detail:
I have a form with a rich-text field on it call ‘ChemFormula’.
I want to pick up the contents of this field and put it in a variable called ‘molForm’.
I then want to change the string which molForm contains by adding some text to it which is subscripted.
Then I want to put the string which molForm contains back into the rich-text field call ‘ChemFormula’.
The code I have so far is shown below.
(The code doesn’t seem to do anything, so I’m obviously missing something.)
I am going about this the wrong way?
Dim rtItem As NotesRichTextItem
Set rtItem = New NotesRichTextItem(doc, "Text")
Call rtItem.AppendStyle(richStyle)
Call rtItem.AppendText(molForm)
Call rtItem.AppendText(" added text")
Msgbox ("Molecular Formula = " & molForm & Chr(10) & "rtItem = " & "Body")
Call doc.ChemFormula.AppendText(rtItem)
Call doc.Save(True,False)
You may be going the long way to get what you want. Does this do what you want?
Set rtItem = doc.getFirstItem( "ChemFormula")
Msgbox "ChemFormula = " & rtItem.text
