I’m expanding the original question because the issue is broader than described and affects versions 5, 6, 7 & 8.
To reproduce:
1.) Create an email with rich text formatting in body.
2.) Save as Draft
3.) Open email from Draft Folder
4.) Click Send
→ Email will be sent with rich text formatting preserved as expected.
BUT – use LotusScript(Send), @Mailsend - with or without parameters - to send the same document and the formatting is stripped from the email.
The same behavior occurs when re-sending an email from the sent folder (or anywhere else, for that matter). The Send Button will send the email with rich text preserved, while any of the other methods result in a plain-text email.
Our ultimate goal is to use an Agent to send (or resend) an email for a variety of reasons… and we have all the desired functionality EXCEPT the ability to send rich text in the body field.
Subject: Rich text not preserved when using LotusScript(Send) or @Mailsend
I do this without issue. There has to be something else going on that you aren’t pointing out.
This simple function should do it.
Function SendDocumentasEmail (doc As NotesDocument) As boolean
Dim mailservername As String
Dim mailbox As NotesDatabase
Dim maildoc As notesdocument
Dim rtitemSource As NotesRichTextItem
Dim rtitemTarget As NotesRichTextItem
SendDocumentasEmail = False 'set default return state to false
mailservername = session.Currentdatabase.Server
' Using mail.box directly is unsupported, but is the
' only way to make the mail look like it is actually
' sent from another address, in our case the principal.
Set mailbox = New NotesDatabase(mailservername,"mail.box")
If mailbox.Isopen = False Then
Print "mail.box on " & mailservername & " could not be opened"
Exit Function
If Not (doc Is Nothing) Then
Set maildoc = New NotesDocument(mailbox) ' Create New document in mail.box
'Call doc.CopyAllItems( maildoc, True ) 'Copy the document to mail.box
Else
Print "No document was passed to SendDocumentAsMail"
Exit Function
Call maildoc.ReplaceItemValue("Form","Memo")
Call maildoc.ReplaceItemValue("Subject","This is the subject")
Call maildoc.ReplaceItemValue("SendTo","user@widgets.com")
Call maildoc.ReplaceItemValue("Recipients","user@widgets.com")
Call maildoc.ReplaceItemValue("Principal", "Carl Tyler/ACME")
' We want it so mail looks like it is coming from that address, need to set these fields
Call maildoc.ReplaceItemValue("From", "Carl Tyler/ACME")
Call maildoc.ReplaceItemValue("SMTPOriginator", "ctyler@acme.com")
Set rtitemTarget = New NotesRichTextItem(maildoc, "Body" )
Set rtitemSource = maildoc.GetFirstItem("Body")
Call rtitemTarget.AppendRTItem( rtitemSource )
Call rtitemSource.Remove
Call maildoc.Save( True, True )
SendDocumentasEmail=True
Exit Function
ErrorHandler:
Print Error$ + " --- Line in SendDocumentssEmail: " + Str$(Erl)
Exit Function
Subject: RE: Rich text not preserved when using LotusScript(Send) or @Mailsend
Carl:
I dropped your script into an Agent and it executes reliably. Thanks for passing that along.
While the contents of the Rich Text field do get copied, however, once the email gets to the recipient, any formatting is removed – the message essentially arrives as Plain Text with the original in-line images stripped and added as attachments.
This has been my challenge all along.
Opening an existing email, whether from Sent or Drafts, and clicking the “Send” button, sends the email while preserving all RT formatting, including in-line images.
Any other method of sending (a draft), re-sending (from Sent), or copying-and-resending (as in your code), results in stripped formatting.
I want to add that the issue exists whether sent out via SMTP.BOX (my desired functionality) or via MAIL.BOX.
Much appreciated, Carl.
I like your approach to forcing a particular “SentBy”… we accomplished this with switching user IDs, but your method is much, much cleaner!
For testing purposes, can I safely drop the code into an Agent that I run manually from the Action Menu and have it process the currently selected document (email)?
