I have a rich text field set to “Best Fit for OS” and have it within a DIV with a style=“position:absolute; top:100”. The editor will not fully load if the position is set to absolute. If I change it to relative it will work, but why wont it work with absolute? Has anyone else had this issue? And is there a solution?
To test make a simple form like this:
<–put rich text field here–>
Thanks for any help
