Reverse Proxy Rewrite Issue
Hope someone can suggest something…
I’m trying to get Reverse Proxy running on Apache, working with DWA in a VMWare environment.
It works great when accessing the email using windows and IE, but when trying to access it using an iPhone\Safari, I get a “Redirecting” and then the dialog “Cannot Open Page, because the server cannot be found.”
Below is an excerpt from the virtual hosts.conf
VirtualHost *:443>
ServerName my.server.com:443
ServerAdmin joe.doe@myserver.com
SSLEngine on
SSLCipherSuite ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv2:+EXP:+eNULL
SSLCertificateFile conf/ssl.crt/domino.mycompany.cert
SSLCertificateKeyFile conf/ssl.key/domino.mycompany.key
SetEnvIf User-Agent ".*MSIE.*" \
         nokeepalive ssl-unclean-shutdown \
         downgrade-1.0 force-response-1.0
RewriteEngine On
#RewriteRule ^/(.*) \http://domino.mycompany.com:81/$1 [P]
