Retrieving values from another column in the same view
Hi
In 3. column i view1 I have some calculated code, wich results in an output value.
In 5 column in the same view I need to use this output value. How is this possible?
Subject: recalculate
You can’t go back and read the other column to create your new column. You need to do the calculation again. So, a simplified example:
if column1 has as a formula:
price1 + price2
then column 5 formula might be:
subtotal := price1 + price2;
subtotal + tax;
Subject: it didn’t do it
I tried recalculating, but it did’nt do it. The 3rd column has multiple values and multible values is posted in new lines and that seemed to make a problem. However i solved the issue by making an ekstra computed field on the form.
thx for answering.
Tom
