Restriction in SMTP Inbound Connection Control
Hi folksI have a question about the Domino Server Configuration field “Allow connections only from the following SMTP Internet host names/IP addresses” under the Tab “Router/SMTP > SMTP Inbound Controls” by Server Configuration in names.nsf:
Is there any limit for this field? (like, you can only entry 2000 entrys or something else).
Thanks for your input.
Simon
Subject: Restriction in SMTP Inbound Connection Control
Don’t know of any entry limit, but a limit is the normal field size limit, which is 15KB I think.
Subject: RE: Restriction in SMTP Inbound Connection Control
ok, thanks for thirst time. If anybody knows more, please let me know.greetings
simon
