Response XML Problem
The responseXML functionality is not working in IE. Is there any workaround for the same.
Regards
Sameer
Subject: Response XML Problem
Yes it very much does work in IE 6 and 7. I would look in more detail at your code. responseXML doesn’t work in FireFox unless the header comes back as text/xml.
Subject: RE: Response XML Problem
Hi Adam this is the code written onchange even of a drop down list
var xmlHTTP;
server=window.location.hostname;
//alert(window.opener.document.forms[0].Pathname.value)
db= window.opener.document.forms[0].Pathname.value;
var SelectBy = document.getElementById(“Selectby”);
//alert(SelectBy.options[SelectBy.selectedIndex].text);
//var vals = new Array()
var url = “http://”+server+“/”+db+“/xmlTest?OpenAgent&SelectBy=”+SelectBy.options[SelectBy.selectedIndex].text;
alert(1)
//vals= dbColumn(server,db,“SAPRoles”,1)
alert(2)
alert(url)
try
xmlHTTP = new XMLHTTPRequest();
alert(2)
catch(e)
try
xmlHTTP = new ActiveXObject(“Msxml2.HTTP”);
alert(3)
catch(e)
try
xmlHTTP = new ActiveXObject(“Microsoft.XMLHTTP”);
alert(4)
catch(e)
alert(“Your browser doesnt support ajax”);
return false;
//if(xmlHTTP!=“”)
xmlHTTP.onreadystatechange = StateChanged;
alert(4.2)
xmlHTTP.open(“GET”,url,true);
xmlHTTP.setRequestHeader(“Content-Type”, “text/xml”)
alert(4.3)
xmlHTTP.send(null)
alert(4.4)
alert(5)
function StateChanged()
//alert(5.1)
if(xmlHTTP.readyState==4)
alert(6)
var xmlDoc = xmlHTTP.responseXML.documentElement;
alert(xmlHTTP.getResponseHeader(“Content-Type”));
alert(6.1)
if(!xmlDoc)
alert(“XMLDOC IS NOTHING”)
alert("Response XML: "+xmlDoc);
var b = xmlHTTP.responseText;
//alert(b.getElementsByTagName(‘root’)[0].nodeName)
//alert(xmlDoc.getElementsByTagName(‘value’)[0].nodeName)
alert(b);
var body = document.body;
var newEle = document.createElement(‘div’);
newEle.setAttribute(‘id’,‘xml’);
newEle.setAttribute(‘innerHTML’,b);
body.appendChild(newEle)
alert(7)
var xmlDoc = document.getElementById(‘xml’);
alert(8)
if(xmlDoc==null)
alert(“xml doc is null”)
//alert(xmlDoc.childNodes.length)
alert("Node name of document : "+xmlDoc.nodeName)
alert(“Node Name of first child”+xmlDoc.childNodes[1].nodeName)
//var xmlRootEle = xmlDoc.childNodes;
if(xmlRootEle.hasChildNodes())
alert(“has child”);
else
alert(“Doesnt have any child”);
alert(xmlRootEle.childNodes[0].nodeName);
alert(9)
//document.getElementById(“test”).innerHTML=b.getElementsByTagName(“value”)[0].childNodes[0].nodeValue
document.forms[0].test.value = b;
As well as i have created an agent which contains the following code
Dim s As New notessession
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim param As Variant
Set doc = s.DocumentContext
param = Evaluate(|@Middle(Query_String_Decoded;"&SelectBy=";"&")|,doc)
Msgbox "Param value" & param(0)
Dim sapRolesView As NotesView
Dim viewDoc As NotesDocument
Set db = s.CurrentDatabase
Set sapRolesView = db.GetView("SAPRoles")
Set viewDoc = sapRolesView.GetFirstDocument
mstr = "<?xml version'1.0'?><root>"
If param(0)="By Roles Description" Then
	While Not viewDoc Is Nothing
		mstr = mstr+"<val>"+viewDoc.RoleDescription(0)+"</val>"
		Set viewDoc = sapRolesView.GetNextDocument(viewDoc)
	Wend
Elseif param(0)="By Role Name" Then
		mstr = mstr+"<val>"+viewDoc.Role(0)+"</val>"
	Wend
mstr = mstr+"</root>"
Print "Content-Type: text/xml"
Print mstr
Kindly request you to help as quick as possible
Regards
Sameer
Do you get something back from responseText but not responseXML? If so the xml you are sending over might not be well-formed and the parser is not able to interpret it.
Cheers
Adam.
