Hi
I’ve created a new resource in our RnR db and it’s not working properly.
It doesn’t appear when doing a search for a resource. It does appear on the list of resources when looking one up in a new calendar entry, but under it’s own site (even though the name of the site is the same - we only have one site).
If I look at the document in the RnR db the site name is exactly the same, and if I look at the hidden categorized views, this resource shows up under the correct site with all the other resources.
I’ve deleted and recreated clubusy already but that didn’t fix it. I’ve also deleted and recreated the resource but no joy.
Can anyone help?
Cheers
Dan
Subject: Resource problem
Is the rrmgr process running coorectly on your R7 server?
From Alan Lepofsky (IBM)
Rooms and Resources Design in Lotus Notes/Domino 7: Learn about how we’ve improved the design and function of the Rooms and Resources feature in Lotus Notes/Domino 7.
New Rooms and Resources features in Lotus Notes/Domino 7 part 2.
Important R&R related technotes:
- How the new Rooms and Resources Manager works in Domino 7
- Functional changes in Domino 7 for reservations directly booked in the Resource database
- What is the purpose of the RnRMgr task in ND7?
- Clustering the Domino 7 Resource Reservations database
- How do Advance limits on reserving a room or resource work in Domino 7?
JYR
Subject: RE: Resource problem
It’s been working fine for the current resources ever since the upgrade to 7, so I can only assume it is. If I show tasks Rooms and Resources is showing, and when I recreated the clubusy I had to stop and start that task.
Dan
