When trying to delete a specific reservation from our R&R database, we get the error “Variant does not contain a container” and the reservation can’t be deleted. Does anyone have suggestions on what this means and how I can delete this reservation? Thanks in advance.
Subject: Reservation DB - Variant does not contain a container error
Turning the debugger on will help you to see the line where the code fails.
Post this line here.
-v
Subject: RE: Reservation DB - Variant does not contain a container error
Can you please tell me how to do that?
This could be due to database corruption.
Running database maintenance against the R&R Manager database could resolve this problem:
Make sure you have a current back up of the database before running this maintenance as any corrupt documents will be deleted by the Fixup command.
From the Domino console, run the following commands:
load fixup databasename.nsf -F
load compact databasename.nsf -c -i
load updall databasename.nsf -R
