Rescheduling Repeat Meetings more than once - problems
We are getting ready to update our server/clients/templates to 6.5.1. In the past, we have seen numerous problems with repeating meetings that are rescheduled more than once. The most common problem is the duplicate entry on the calendar. If the user then attempts to remove one of the ‘duplicates’ both are removed.
Example:
Can anyone tell me if this problem has been resolved or improved in 6.5.1? If so, I would love to trumpet that improvement, it would make our user’s lives a bit easier.
Thanks,
Lori
Subject: Rescheduling Repeat Meetings more than once - problems
We are having this issue as well. Does anyone have a solution?
