REPOST: @Command(MailComposeMemo) problem
One of my users is having a strange problem after upgrading his laptop. We have a rather large reporting db, which stores reports and their attachments. The doc has a hotspot which copies the doc title and two fields (one for To: one for CC:) and the attachment(s) into a new email.
However, when the user clicks the ‘Click to email attachment’ hotspot, instead of creating a new email, the subject, recipients and the attachment itself are copied into the attachment field.
No-one else is having this problem, so I doubt it’s a coding error, but more of a client setting issue, seeing as the hotspot worked before his laptop upgrade. Has anyone heard of this before and how to solve it?
This doesn’t seem like a big issue right now, but we’re due to upgrade a large number of laptops in the coming weeks, and I don’t want this becoming an issue for everyone.
TIA,
Nicola.
Subject: REPOST: @Command(MailComposeMemo) problem
Close Notes,
Delete the cache.ndk, file
fixup and compact db (on server if exists there or do on client)
launch notes
fixup/compact if not done earlier
Try again.
Subject: RE: REPOST: @Command(MailComposeMemo) problem
Thanks for your reply.
The user is actually over in France, so I’ll send on your suggestions and get back to you with the result.
Thanks again,
Nicola.
