Replication problems
Dear All,
We have two domains (A and B), two servers (serverA and serverB) , one db (dbA - hidden design).
We did crosscertification. On my side i did server document and server connection document. My server is listed in db ACL as manager (server), there are also LocaDomainServer (server group - manager), OtherDomainServer (server group - reader) and “source” server (serverA - manager) with enforce ACL. I did replica on my server (serverB) and after that i can not make replication working… :frowning:
those messages i have in my log (console serverB):
Remote console command issued by Admin: replicate serverA bdA
Database Replicator started
Replicator is set to Ignore Database Quotas
Starting replication with server serverA
Access control is set in dbA to not allow replication from serverA dbA
Pushing dbA to serverA dbA
The ACL in database serverA!!dbA has been changed by dbA
Unable to store document in serverA dbA (NoteID = 282) from dbA (NoteID = 298): View and Design notes can only be deleted by using NIFUpdateNote or NIFDeleteNote.
Replicator added 2 document(s) to serverA dbA from dbA
Replicator deleted 2 274 document(s) in serverA dbA from dbA
Finished replication with serverA
Database Replicator shutdown
what is going on?!
Subject: Replication problems…
Hi, Please check the ACL correctly, i am sure there is some error in that
and you could also try to remove the consistent ACL and give it a try.
