One of my mobile user having problem to replicate to the server.When he click start now in replication page, nothing happen.
He can connect directly to the server, and he can replicate through foregound. It seem somehow the replication page is corrupt? Or the background replication is not working.
Try this:Delete the item(s) you are trying to replicate with from the Replicator page itself.
Then either drag the icons from your Workspace on to the Replicator Page, you need to drag them on to the Replicator Page Icon on the Bookmark bar.
or
Right Click your icon, select Replicate and Replicate via Background Replicator.
Suggest you may want to delete the icons from your Workspace page, Compact the Workspace and take the icons again by opening the Server and Local Replicas to ensure you have the correct icons on the Workspace.
After searching the forum, I found that is a similiar question with answer.The answer, wait for 30 minutes and try again. It said that lotus notes client is doing something in the background that prevent background replication to run.
Wait for 1 hour (lotus notes open), and try again… success.
