Replication or Save Conflict Problem
All,
This is for the Notes Client… Now I am having an issue with the category and will change it to see if I can post…
I am having a strange issue with a replication or save conflict problem.
In my design databse I have a form with Merge Conflicts selected.
When I go into this form, Enter data in a field then press the enter field, followed by tabbing through some fields, press save and close, then I get a Replication or Save Conflict message. A replicate is created.
There is no one else in the development database that I am in. I have checked to see if I have any agents scheduled during this time and I do not.
This is the code in my Save button:
@PostedCommand([FileSave]);
@PostedCommand([FileCloseWindow])
I do have some lookups and mail send on the Querysave event, but I do not have any saves here.
I have checked my hidden fields and can not find any of them calling an agent.
If I open up the document change a field, hit enter, and save. There is no replication.
If I go in the form and just tab through the form, I get a replication.
What am I doing wrong? How can I fix this?
Teri
Subject: Replication or Save Conflict Problem
Check all yr events of the form, “QuerySave”, “PostSave”, “Querymodechange” etc etc.
Also check “Exiting” events of those fields. Some kind of 2nd “save” is creating these conflicts when u try to Save it manually. You can also try using LS .save method wherein you can restrict others to save the document when u r saving.
Hope it helps.
