ReplicateWithServer LS to API code problem
Hi all,
I am trying to create a replica of the Personal Address Book onto a server.
Error : 5646
I am struggling to troubleshoot this error message. Any ideas?
Option Public
Option Declare
'Declarations*
'STATUS LNPUBLIC ReplicateWithServer(char far *PortName,char far *ServerName,WORD Options,WORD NumFiles,const char far *FileList,REPLSERVSTATS far *retStats);
%REM
#define REPL_OPTION_RCV_NOTES 0x00000001 /* Receive notes from server (pull) */
#define REPL_OPTION_SEND_NOTES 0x00000002 /* Send notes to server (push) */
#define REPL_OPTION_ALL_DBS 0x00000004 /* Replicate all database files */
#define REPL_OPTION_CLOSE_SESS 0x00000040 /* Close sessions when done */
#define REPL_OPTION_ALL_NTFS 0x00000400 /* Replicate NTFs as well */
#define REPL_OPTION_PRI_LOW 0x00000000 /* Low, Medium, & High priority databases*/
#define REPL_OPTION_PRI_MED 0x00004000 /* Medium & High priority databases only*/
#define REPL_OPTION_PRI_HI 0x00008000 /* High priority databases only*/
%END REM
'LotusScript code**
Public Const REPL_OPTION_RCV_NOTES& = &H00000001
Public Const REPL_OPTION_SEND_NOTES& = &H00000002
Type REPLSERVSTATS
Pull As Variant
Push As Variant
StubsInitialized As Long
TotalUnreadExchanges As Long
NumberErrors As Long
LastError As Integer
End Type
Type pREPLSERVSTATS
Pull As REPLSERVSTATS
Push As REPLSERVSTATS
End Type
Declare Function W32_ReplicateWithServer Lib “nnotes.dll” Alias “ReplicateWithServer” _
(Byval PortName As Lmbcs String, _
Byval ServerName As Lmbcs String, _
Byval Options As Integer, _
Byval NumFiles As Integer, _
Byval FileList As String,_
retStats As pREPLSERVSTATS) As Integer
Dim Result As Long
Dim PortName As String
Dim ServerName As String
Dim Options As Integer
Dim NumFiles As Integer
Dim FileList As String
Dim retStats As Long
Dim repStats As pREPLSERVSTATS
Sub Initialize
PortName = "TCPIP"
ServerName = "CN=popper/OU=servers/OU=london/O=glen"
Options = 2
'REPL_OPTION_RCV_NOTES Or REPL_OPTION_SEND_NOTES
FileList = "bbnabs\pthomas\names.nsf"
result = W32_ReplicateWithServer( PortName,ServerName, Options,1,FileList, repStats)
If (result <> False) Then
	Msgbox "Error: " & result
Help !!
Paul
Subject: My guess is that there is not a replica of the File on the server you are trying to replicate with.
Subject: ReplicateWithServer LS to API code problem
Bill is right. You can use the function below (or some variation of it) to gather additional information about the return code from the API. So if I use it and plug in your return code as follows:
Dim intErrCode As Integer
Dim strErrTxt As String
intErrCode% = 5646
Call getAPIErrorDesc(intErrCode%, strErrTxt$)
Msgbox "Error " & intErrCode% & ": " & strErrTxt$ & ".", , "DEBUG . . ."
Print "Error " & intErrCode% & ": " & strErrTxt$ & " . . ."
The message text I get back is “None of the selected databases has a replica on the server”.
hth,
dgg
Declare Function W32OSLoadString Lib “nnotes” Alias “OSLoadString” ( _
Byval hMod As Long, _
Byval stringCode As Integer, _
Byval retBuff As Lmbcs String, _
Byval buffLen As Integer _
) As Integer
Private Sub getAPIErrorDesc(pintRetCode As Integer, pstrErrMsg As String)
'// +++ GLOBAL VARIABLES +++
'// Constants:
'// <add global constants, if any, here>
'// Class instances:
'// <add global class instances, if any, here>
'// 08/09/2002 - Dallas Gimpel
'// DESCRIPTION:
'// This sub takes the unmodified return code returned by an api call and “decodes” it
'// into a more familiar error number. It then returns the text associated with the given
'// error number by making an api call which loads the text into a string variable. If
'// no text is returned for the given error, it defaults to “unknown error”.
'// INPUT:
'// pintRetCode - Integer, the original return code as returned from the api call
'// OUTPUT:
'// pintRetCode - Integer, modified by “Anding” the error mask to it to produce a “kinder & gentler” error
'// pstrErrMsg - String, the text of the error message as returned by the api
Const NULL_HANDLE = 0&
Const ERROR_MASK = &H3fff '// see globerr.h
Const BUFFER_SIZE% = 255
Const UNKOWN_ERR_DESC$ = "unknown error"
Dim intLength As Integer
pstrErrMsg$ = String$(BUFFER_SIZE + 1, 0)
pintRetCode% = pintRetCode% And ERROR_MASK
intLength% = W32OSLoadString(NULL_HANDLE, pintRetCode%, pstrErrMsg$, BUFFER_SIZE)
If intLength% > 0 Then '// if we get a valid error description back, use it
	pstrErrMsg$ = Fulltrim(pstrErrMsg$)
Else
	pstrErrMsg$ = UNKOWN_ERR_DESC
Subject: RE: ReplicateWithServer LS to API code problem
OK,
I am getting error 15740
You are not authorised to replicate or copy data from this database
I have full Mangler Access with all roles.
This error occurs if run on the Server replica or on the Local Replica
Any Ideas
Hi all,
OK, I was under the impression that the code would create the replica if none existed.
Anyway, I have created the replica. The code returns no error now, but does absolutely nothing.
Am I missing something?
P.S All I need to do is get a user to click on a button. It…
1/ Amends the ACL of their Personal NAB - Done
2/ Amends the Locations Doc for Replication - Done
3/ Creates a replica on their local server - Done
4/ PROBLEM - Adds the replication to the replicator page.
Any ideas?
Put the server name explicitly in the ACL of the local replica. R6 quirk.
By the way, you could have done this via the NotesDatabase.Replicate() method in LotusScript as well.
e.g.
Set dbReplica = New NotesDatabase(“”, “”)
Call dbReplica.Open(“”, strReplicaDb)
If (dbReplica.IsOpen()) Then
‘’‘’ ’ must use canonical format here as of R6.53
intReturnValue = dbReplica.Replicate(nnServerName.Canonical)
Hi Timothy,
This is still not working. I am using the following code. Am I going mad?
	Set dbreplica = New NotesDatabase("", "names.nsf")
		Set replica = dbreplica.CreateReplica(conservname, path)
		Call workspace.AddDatabase(conservname, path)
		Call workspace.OpenDatabase(conservname, path)
		flag = dbreplica.Replicate( conservname )
Quick overview…
createReplica() will fail if the file already exists. Use it if there is no replica in place.
Use replicate() if the replica is in place already.
replicate() only works if the replica server is listed explicity in the ACL of the local replica in either abbreviated or canonical format.
AKA. “LocalDomainServers” is not sufficient.
replicate() only works if the server name parameter is in canonical format.
You may need to verify the server is the ACL in LotusScript after the
Set replica = dbreplica.CreateReplica(…) call.
If not, create the entry.
e.g. something like:
Dim nnServerName as NotesName
Dim acl As NotesACL
Dim entry As NotesACLEntry
Dim conservername as String
Set dbreplica = New NotesDatabase(“”, “names.nsf”)
Set nnServerName = New NotesName(conservname)
conservername = nnServerName.canonical
if (Not (dbreplica.IsOpen)) Then Call dbReplica.open(dbReplica.serverName, dbReplica.FilePath)
Set acl = dbReplica.ACL
Set entry = acl.GetEntry(conservername )
If (entry is Nothing) Then
Set entry = New NotesACLEntry( acl, conservername, ACLLEVEL_MANAGER )
call acl.save()
Set replica = dbreplica.CreateReplica(conservername, path)
Call workspace.AddDatabase(conservername, path)
Call workspace.OpenDatabase(conservername, path)
flag = dbreplica.Replicate( conservername)
(untested)
