ReplicateWithServer LS to API code problem
Hi all,
I have no experience in LS to NotesAPI programming, but have located some documentation to assist.
But in order to use the documentation, I need to understand how to Declare and Call in the code.
I am trying to create a Replica on a server so it appears in the Replication Page.
But the following compile error occurs -
Illegal Function Return Type for : REPLICATEWITHSERVER
Declarations
'STATUS LNPUBLIC ReplicateWithServer(char far *PortName,char far *ServerName,WORD Options,WORD NumFiles,const char far *FileList,REPLSERVSTATS far *retStats);
Declare Function ReplicateWithServer Lib “nnotes.dll” (Byval PortName As String, Byval ServerName As String, Byval Options As Integer, Byval NumFiles As Integer, Byval FileList As String, retStats As String)
LotusScript code**
Sub Initialize
Dim Result As Long
Dim PortName As String
Dim ServerName As String
Dim Options As Integer
Dim NumFiles As Integer
Dim FileList As String
Dim retStats As String
PortName = "0"
ServerName = "CN=bacon/OU=servers/O=glen"
Options = "0"
FileList = "names.nsf"
result = ReplicateWithServer( PortName,ServerName, Options,1,FileList, retStats)
Any help to get me started would be appreciated. I am looking to get a book, but I need to complete this code asap for a rollout.
Subject: ReplicateWithServer LS to API code problem
Try this. Notice options and declare statement changes. Also for simplicity, I am not trying to capture the “retStats” data.
Option Public
Option Declare
'Declarations*
%REM
#define REPL_OPTION_RCV_NOTES 0x00000001 /* Receive notes from server (pull) */
#define REPL_OPTION_SEND_NOTES 0x00000002 /* Send notes to server (push) */
#define REPL_OPTION_ALL_DBS 0x00000004 /* Replicate all database files */
#define REPL_OPTION_CLOSE_SESS 0x00000040 /* Close sessions when done */
#define REPL_OPTION_ALL_NTFS 0x00000400 /* Replicate NTFs as well */
#define REPL_OPTION_PRI_LOW 0x00000000 /* Low, Medium, & High priority databases*/
#define REPL_OPTION_PRI_MED 0x00004000 /* Medium & High priority databases only*/
#define REPL_OPTION_PRI_HI 0x00008000 /* High priority databases only*/
%END REM
'LotusScript code**
Declare Function W32_ReplicateWithServer Lib “nnotes.dll” Alias “ReplicateWithServer” _
(Byval PortName As Lmbcs String, _
Byval ServerName As Lmbcs String, _
Byval Options As Integer, _
Byval NumFiles As Integer, _
Byval FileList As String,_
Byval retStats As Long) As Integer
Public Const REPL_OPTION_RCV_NOTES& = &H00000001
Public Const REPL_OPTION_SEND_NOTES& = &H00000002
Sub Initialize
Dim Result As Long
Dim retStats As Long
PortName = "TCPIP"
Options =  REPL_OPTION_RCV_NOTES Or REPL_OPTION_SEND_NOTES
result = W32_ReplicateWithServer( PortName,ServerName, Options,1,FileList, 0&)
If (result <> False) Then
	Msgbox "Error: " & result
edit
However, if repStats is important (if you wish to log the number of replication exchanges somewhere), this would work:
Type REPLSERVSTATS
Pull As Variant
Push As Variant
StubsInitialized As Long
TotalUnreadExchanges As Long
NumberErrors As Long
LastError As Integer
End Type
Type pREPLSERVSTATS
Pull As REPLSERVSTATS
Push As REPLSERVSTATS
End Type
retStats As pREPLSERVSTATS) As Integer
Dim repStats As pREPLSERVSTATS
result = W32_ReplicateWithServer( PortName,ServerName, Options,1,FileList, repStats)
Subject: RE: ReplicateWithServer LS to API code problem
Hi Timothy,
I keep getting an error 5646 when run.
But not sure how I can troubleshoot this error message.
Any ideas?
Check your port name. On location document, under ports.
Also, verify replica exists on that server.
Refer to the OSLoadString function to convert the error into something more meaningful.
-Brian
