When I hit the Replicate icon in my toolbar from the Mail View, I’m prompted with a pop-up window asking if I want to Replicate with or without options.
May the function be changed such that the default operation is to replicate without options, or, have the ability to define the default behavior? Or, possibly two different Replicate icons - one that has options, the other that doesn’t.
This might be an argument of semantics, but it seems like a pop-up box to ask if you want options is an option in itself, and therefore, the non-default or lesser-used behavior.
Bottom line is that I’d like a simple icon that will send my pending outgoing mail and retrieve my waiting incoming mail with 1 click.
(This “Bottom Line” also encompasses my previous post/request to have the replicate icon also send my pending outgoing mail: http://www-10.lotus.com/ldd/nd8forum.nsf/DateAllThreadedWeb/55c91383bee33dca8525744e00790605?OpenDocument)
Thanks!
