I have a db that will be on multiple server and users will replicate it as well. It only has 2 forms.
If I make a private view for replica conflics, how to I maintain it? Do I just go in a look at them? How does this work?
I assume I just make a form with the field form and then have the view selection to this:SELECT @IsAvailable($Conflict)
I guess my main concern is how do I maintain this? Also, I assume I need to set the form to “create conflicts”. Thanks…
Subject: replica conflict help
I have a view in one of my web nabs like this. Yes, it will update. It will only show the <>[Replication or Save Conflict] in the view, so unless it is just so you can mass delete, you have to open to see who the conflict belongs to. Of course, I haven’t really tried to change this since that I use it just to delete conflicts.
Subject: RE: replica conflict help
How does notes know that the conflict is bad? I assume it’s best to create the private view like this correct?
I’ll have this db on several servers. I guess document locking is not the way to go.
Thanks for for the reply…
It doesn’t know whether the conflict is the one you want or not…It could very well be something that needs to be kept. If the replication errors are because two users have the document open, then that would be another issue. If they are caused when a replica is done, then if a document in the replica db has been modified AFTER the main db, it will cause a replication error. Does that make sense and I hope I explained it right…(I’m sure I may be corrected if not)
