Hyif I try to replicate a db between two servers, on server console I find this message:
“Replicator was unable to initialize SERVERNAME/DOMAIN DIR\SUBDIR\BDNAME.NSF (from DIR\SUBDIR\BDNAME.NSF): Replication cannot proceed because cannot maintain uniform access control list on replicas.”
Any idea??
Thanks to all
Subject: Replica between servers! Problem…
Looks like the the database on one of the server replicas has the enforce consistent ACL set - this is normally controlled by the administration server specified under database access control - advanced section. I’m afraid that you are going to have to make sure your replica ACL has the same ACL settings of the Administration server replica before any data can be replicated. Failure to get this right, you will need to pull a new replica of the database in order to get the data.
As always backup databases before you delete them.
Jaime
Subject: RE: Replica between servers! Problem…
Many thanks for your help.
Have a good day!!!
