Hello all,
I performed a rename function on two users yesterday. It appears to have at least partially worked. In the admin people list it shows the proper new name, but in the clients’ directory listing it still shows the old name. And the users’ administration tab still shows “pending”.
I checked the admin request log and I saw this for both entries:
Title: DOMAIN.COM’s Address Book File name: names.nsf; Error: Your public key does not match the one stored in the Address Book
How can I correct this so the rename fully completes?
Thanks!!
Brad
Subject: Rename Users - Help
The public key issue for your ID needs to be fixed but that is not the rename problem.To do a rename:
Be on the registration server with the certlog.nsf…go to people/groups tab.
Find the user…either rightclick or choose Tools…rename
CHoose Change Common name…You need access to the certifier where the user is currently certified…if the user is Jon Brown/ABC you need the cert.id (O level certifier) if the name is Jane Smith/Sales/ABC then you need the OU level certifier. Change internet address if desired. Click OK
You should see N entries selected…N entries sucessful or something like that.
NOW…in admin4.nsf on the registration server there will be an Initiate Rename in Address book request. You can kick off adminp or wait for the default 60 minute interval…to do it now…select any adminp trask on the server tasks window right click…Tell…Process (New or All Requests)
The name will change in the directory…at this point you have to wiat for the user to accept the new name. This will happen the next time they log on/off to Notes. THe next request is Rename in Domino DIrectory…(group doc, etc)…there will be 5 or 6 requests relative to the name change generated AFTER a user accpets the new name. Either wait or tell adminp to do its thing.
One note: If the users home mail server is DIFFERENT from the reigstration/admin server you will have ot wait until not only adminp carries out its taks but also for the names.nsf to replicate.
On the off chance that the user uses iNotes only or never uses their notes ID you will need to force this name change by locating a copy of the ID file and signing on as them to begin the process.
Hope this hleps
Subject: RE: Rename Users - Help
Thank you for that very informative response, I really appreciate it.
Brad
