I have two test accounts that I use for proving iPhone configuration of mail files on different servers using the same device. Traveler shows my name and these two other test account names as having the same ApplID.
Is there a command that allows me to just remove the user from traveler without specifying the device ID ? For instance, a command similar to “tell traveler delete ” but without the device ?
If I delete a test account using the same ApplID will that ban my account which uses the same device ID ?
