Remove duplicates errors/problems
Hello,i am trying to create a script to remove double entries in a folder from lotus. i do not know what is wrong, sometimes the script just stops, sometimes i get the error that the Object varioable not set (or something like that.
I have checked with the debugger, and the error of variable not set comes to dco1 8in the script) which makes no sense, because the loop should exit when doc1 is nothing.
when running the script in debugger and checking variable values, i see very strange things happening, namely with doc1 values, sometimes , after a document has been deleted, it does not get the next value (when saying getnext) but the last value of the whole list of documents, which makes no sense (to me and a colleague that looked with me)
Can anybody help
here is the script, i use a lot of variables because i have seen in the forums that using a getnext with the same variable can cause errors
Dim db As notesdatabase
Dim allhtml As NotesView
Dim doc1 As notesdocument
Dim doc2 As notesdocument
Dim doc3 As notesdocument
Dim doc4 As notesdocument
Dim doc5 As notesdocument
Dim doc6 As notesdocument
Dim messago As String
Dim messag2 As String
Set db =session.currentdatabase
Set allhtml = db.getview("HTMLPDFSent")
Set doc1=allhtml.getlastdocument
Set doc4 = doc1
Do While Not (doc1 Is Nothing)
	Set doc4 = doc1
	Set doc2 = allhtml.getprevdocument (doc1)
	Do While Not (doc2 Is Nothing)
	'	Messagebox doc2.Subject (0), MB_OK, "doc2"
		Set doc6 = doc2
		If Trim(Ucase(doc1.Subject(0))) = Trim(Ucase(doc2.Subject(0))) Then
			Set doc3 = doc2
			Set doc2 = allhtml.getprevdocument (doc6)
			doc3.remove True
		Else
	Loop
	Set doc5 = allhtml.getprevdocument (doc4)
	Set doc1 = doc5
	Messagebox doc1.Subject (0), MB_OK, "doc1"
Loop
thanks for any help…
Subject: Remove duplicates errors/problems
Can you write your script in pseudo-code so we know what you are trying to do exactly?
Subject: RE: Remove duplicates errors/problems
Hi Yanick,
i am not sure what pseudo code is, but here is what i am trying to do
look into folder HTMLPDF
take first document (last one that arrived, most recent) (doc1)
do while there are documents in the folder
get next document(doc2)
compare subjects (doc 1 vs doc2)
if they are the same, delete older document(delete doc2)
loop (until doc2 is empty, end of documents)
get next document for doc1 and repeat above for all documents in the folder, until doc1 is empty
basically i am trying to remove duplicates from a folder called HTMLPDF.
so i take the most recent document, compare it with all the following documents and delete any older ones if there are any (with the same subject)
then i repeat this action until i have gone through all the documents in the view.
i thought about having an easier agent run whenever a new document arrives, starting from an empty folder, but i have seen that ‘after new mail arrives’ option does not work like it should, it does not do what it should do right after, but it actually only happens every 5 minutes and then sometimes takes many documents at the same time if they came within that time frame.
What is really strange is that the script works when i follow it in debugger (variables have correct values), but then all of a sudden the doc1 variable is empty, or takes the last value of the list, for no reason since it has not reached the end of the documents of the folder (something wrong with the getnext option?)
i know i could do this script using only doc1 and doc2 but i saw somewhere that this might cause problems, hence the use of all the other variables.
maybe this simpler version of the code is easier to understand
Sub Initialize
Set allhtml = db.getview("HTMLPDF")
messago = doc1.Subject (0)
time1 = doc1.Created
Set doc4 = doc1
allhtml.Autoupdate = True
			Set doc3= doc2
			Set doc2 = allhtml.getprevdocument (doc2)
			doc3.remove True
		Else
	Loop
	Set doc1 = allhtml.getprevdocument (doc1)
Loop
thanks for the help
Hi Thierry,
Try this,
http://www-10.lotus.com/ldd/nd6forum.nsf/DateAllFlatweb/b8bf4454504926f1852572c700408074?OpenDocument
