Hi , i am geting this" remote system not responding " error When my lotus client users from china are about to connect the “domain server” in hongkong.I Am able to ping the domino server even the website on the domino server is opening without any problems.Users from other location are able to connect the domain server without any problem through the client.Only this location has the problem.
I have tried the following things
1)Clicked the “Trace” and selected ip address as well as the domino server name.But still i getting that error.
Reinstalled the lotus client.
Created the new connection document.
Deleted the cache.
Tried from other machine
This problem started on one machine and now all the machine are giving me the same error.
This used to never happen with lotus client 5.08 only this new version 6.5 is giving me this problem , This problem noramlly us to come earlier when ever a user switch ids but after some time the error used to stop , but this time the error is not going …i have tried the admin id also …
I have tried almost every thing but still i am not able to connect ,Trace log is as follows :-
Determining path to server Dss_NOTES/abc
Available Ports: TCPIP LAN0
Checking normal priority connection documents only…
Allowing wild card connection documents…
Checking for Dss_NOTES/abc at last known address ‘202.215.243.33’ on TCPIP…
Unable to connect to Dss_NOTES/abc on TCPIP (Remote system no longer responding)
No answer at last known address
Enabling name service requests and probes…
Checking for Dss_NOTES/abc on TCPIP using address ‘Dss_NOTES’
Unable to connect to Dss_NOTES/abc on TCPIP (The remote server is not a known TCP/IP host.)
Checking for Dss_NOTES/abc on LAN0 using address 'Dss_NOTES
Unable to connect to Dss_NOTES/abc on LAN0 (Remote system not responding)
Checking low and normal priority connection documents…
Local network connection document found for Dss_NOTES/abc
No default passthru server defined
Unable to find any path to Dss_NOTES/abc Group because Remote system no longer responding
Any help with be greatful
