Hi all…Our Domino server resides in Hong Kong while our offices worldwide (North America, Asia) access the server in Hong Kong. Recently, one our offices in China begun experiencing problems connecting to the server using the Notes Client. For the past 4 years, everything went well but off late, we receive an error message “Remote system no longer responding”. I suspect it has to do with our ISP in China who may have made changes at their end which inadvertently affects the access to our server in HK. I even tried doing a trace from the notes client using Files>>Preferences>>User Preferences>>Ports>>Trace…the server IP address could be found. At the same time, I can PING the server’s IP address using the DOS console, no problems.
Has anyone experienced similar circumstances and found a solution?
Subject: Remote system no longer responding !!!
Sounds like an IP port issue.Use a notes client to check IP port connections to your other servers.
Or, nconnect.exe found in the sand pit. With this IP tool you can ping any IP port; 1352, 25, 110, 80 etc very useful to check routers/switches and firewall access as long as the notes client is installed, nconnect calls on a few Notes client DLLs.
http://www.notes.net/sandbox.nsf/ecc552f1ab6e46e4852568a90055c4cd/4a60b6779e52c19c8525679100832651?OpenDocument&Highlight=0,nconnect
Note: Since the client is using DHCP, the DHCP server usually provides the IP address (obviously), DNS and local LAN gateway server address. So the client’s inherited DNS and gateway addresses depend on the accuracy of the WAN’s DNS and routing tables that show the way or block the way to the Domino server back bone.
ping -a iphost
Rgds.
Subject: RE: Remote system no longer responding !!!
I have experienced the same problems for my site’s server.
What i did is to manually add the connection in FIle->Mobile->Locations, then choose Connection. Configure the server name and IP address. After that, restart your computer.
It works for me. Hope it helps you.
Thanks Andrew. Turned out that port 1352 was blocked. Opened it on the router and voila…worked like a charm. Thanks for showing the way.
