Hi All:
Iam using R5 on XP. When I tried to open any database which is on server, Iam getting an error msg “Remote system is not a known TCP/IP Host”…but when I try to acess “webadmin.nsf”, its working fine.
I tried with IP# / Machine name etc…its not working.
What could be the problem?
Any help would be highly appreciated…
Thanks in Advance…
-Nagendra Prasad
Subject: Remote system is not a known TCP/IP Host problem!!!
I had a similar prob and resolved it by changing the Net Address of the server from the Windows hostname to the actual IP.
You’ll need to bounce Domino and it should work after that.
Subject: RE: Remote system is not a known TCP/IP Host problem!!!
Thanks Amjad,
Do u want me to replace the host name with Ip address??? it is a stand alone system…
-Nagendra Prasad
Yep … so in the servers ‘server document’, go to Net Address and change the value to the IP address.
In my case, the Domino Server and the application requesting the name were located on the same box (the app was actually running as a Domino task) but it kept on giving me the same error.
It startd working as soon as I changed to the IP
Subject: The remote server is not a known TCP/IP Host
Hi, Thanks for the info, this solved the “Remote server is not a known TCP/IP Host” that was being displayed when enabling the OOO agent on both inotes and the local clients.
Regards
Robert
