Register users with Lotusscript and ID Vault
In our User Administration Tool, we are using the LotusScript class NotesRegistration to create Domino user accounts. The tool works fine on Domino 8.5 (beta 2).We activated the ID Vault functionality to try it out together with our tool.
When running the scheduled agent with the function NotesRegistration.registerNewUser included, we got this Notes error in return: “Notes error: ID upload to the Notes ID Vault failed”. No user account was created.
But when running the same agent through the Domino Designer client, everything worked fine; the account was created and the id-file ended up in the ID Vault.
The agent is signed with the same ID that ran the agent from the client.
All other functions work when the agent is run from the server.
Is this a bug in the NotesRegistration class? Or is there another explanation?
Best regards Marta Birgoth
Subject: Problem fixed?
I know this post is quiet old but it’s the only one that I found regarding this issue.
I wonder if this problem is really fixed…
Anyway I still have this problem using the RegisterNewUser Method:
“ID upload to the Notes ID Vault failed”
When I create a user using the Admin-Client everything works.
Client Version = 8.5.2
Server Version = 8.5.1 (FP4)
Any info is appreciated
Frank
Subject: We have the problem…
I have implemented the CA process. After that we have this error when we create a user. The user is created, but we still have the user in the registration que with an error ID upload to the Notes ID Vault failedServer 8.5.3 Client 8.5.3
Subject: Will investigate … some questions to clarify
Can you check the security events view in both the client and server log for error messages?
If necessary for us to reproduce, do you have an evaluation version of your tool we can test with?
Subject: Security log messages
Hello Catherine and thanks for the response. Here are the security log messages.
From the server when running the agent from the server console:
2008-10-15 12:01:38 ID ‘C:\treset.id’ failed to upload to vault ‘’ on server ‘CN=Server1/O=Birgoth’. ‘Server1/Birgoth’ made request. Error: Timeout occurred waiting for message.
From the server log as I ran the agent from the client:
2008-10-15 12:04:20 ID successfully synchronized with vault ‘O=SuperVault’ for ‘Test Reset/Blue/Birgoth’ (IP Address 192.168.23.1:58247).
And from the client log:
2008-10-15 12:05:19 ID ‘C:\treset.id’ successfully uploaded/synchronized to vault ‘’ on server ‘CN=Server1/O=Birgoth’ by ‘Resetpassword Admin/Birgoth’.
I will get back to you with some code examples, but basically we just use the NotesRegistration class.
Subject: Sample code
Hello again,
This is an somewhat modified extract from our User Administration Tool, hope this will help.
We do have a demo version of our tool, but it is still in Beta… But please let me know if you need it, and I could send it to you.
Dim userReg As New NotesRegistration
'____________________________________________________________________
'registration defaults
userReg.Expiration= Now() + expDays
userReg.CertifierIDFile = “C:\cert.id”
userReg.IDType = ID_HIERARCHICAL
userReg.MinPasswordLength = 8
userReg.RegistrationServer = “Server1/Birgoth”
userReg.CreateMailDB = False
userReg.StoreIdInAddressbook = False
userReg.IsNorthAmerican = False
'_____________________________________________________________________
'All users, register new user(=ID file)
dim lastName as string
dim idfilePath as string
dim mServer as string
dim firstName as string
dim mInitial as string
dim certPwd as string
dim mFile as string
dim pwd as string
dim licenseType as string
lastName = “Larson”
firstName = “Liza”
mInitial = “”
idfilePath = “C:\llarson.id”
pwd = “xxyx”
mServer = “Server1/Birgoth”
mFile = “mail\llarson.nsf”
certPwd = “password”
licenseType = 176
If Not userReg.RegisterNewUser(lastName, idfilePath, mServer,_
firstName, mInitial, certPwd, “”, “”, mFile, “”,pwd, licenseType) Then
RegisterIDFile = “Could not register user”
Exit Function
'add to DD
If Not userReg.AddUserToAddressbook( idfilePath, fullName, lastName,pwd,_
firstName, mInitial, mServer, mFile, “”, “”, “”) Then
RegisterIDFile = “Could not add user to Domino Directory”
Exit Function
Regards, Marta
Subject: Thanks for additional information, will do some testing
Apologies for delay in getting back to you.
Subject: No problem
Please let me know if you need some additional info or more code examples.
Thanks and best regards, Marta
Subject: SPR# KHON7L2RW6
Still investigating and will have another update (possibly some questions) shortly.
Subject: Fix submitted
Barring any last minute problems with the fix, this problem has been addressed for 8.5. Thanks so much for your help in reporting and diagnosing the problem!
Subject: Thank you too!
This is a very important issue for us, so I am very glad to hear that it will be fixed.
Subject: OK, thanks for keeping me updated
We and our customers are eagerly waiting for your respons.
Best regards, Marta
