We are struck with a problem on our test domino server. I spent almost four days working on this, looked in lotus fourms andadmin doumentation thoroughly but no help. I’m sure fix is very simple, but i just couldn’t figure out where i was going wrong.
Issue:
I was trying to use CA Process & Recovery Information together, but whenever i choose CA process to create OU’s or user ID’s
their backup copies of ID are not getting mail back to mail-in databases. This is what i’m doing;
After finishing up fresh installation and making sure Adminp is working, i migrate certifier O=SUNYIT.
I process all jobs in Admin req. database and do a ‘load ca’. Certifier O=SUNYIT shows as associated with CA Process.
I now edit recovery information using CA Process for this certifier and do ‘tell ca refresh’ → ‘tell adminp process all’ →
‘tell ca refresh’
I made sure no jobs are pending in Admin Req. database.
Now i create OU or user ID’s using CA Process. After updating ca process and running adminp jobs, backup copies of OU’s do
not showup in mail-in database.
- I went ahead and installed Notes client and authenticated user against the server. Left Notes client running on the
workstation.
- Even after waiting few minutes, user’s ID does not show up in mail-in database.
Now if i create OU or user ID’s using certifier ID instead of CA Process,
recovery works and i find Backup copies of ID’s mailed back. At this point i cannot conclude that CA Process is broken because
i’m able to create certificates, but for some reason recovery isn’t working.
I didn’t see any error or warning messages on console. Coudn’t find any errors or pending jobs in Adminp database. Made sure
Registration and Administration servers are same as the server i was working.
I would really appreciate if could help me with this, Thanks
-Raghu
