Recordset Problem
Hello,
I have this code in a agent running on server:
Set cn=createobject(“ADODB.Connection”)
Set rs=createobject("ADODB.Recordset")
cn.Open coneccionstring
sql=“select * from centros_produccion”
Set rs=cn.execute(sql)
Do While rs.eof =False
If Isnull(rs.Fields("lista").value) Then
	valor$=""
Else
	 valor$=rs.Fields("lista").value
lista=lista + Trim$(valor$) + Chr(13) + Chr(10)
rs.movenext
Loop
this code works fine in 8.0 version and return 5 elements on lista, but on 8.5 version just the first, it seems like rs.movenext doesn’t work
Our server is windows 2003 server 64 bits
Thank you for you help
Nina.
