:: readers field not working, using secondary NAB ::
Hi all
the scenario i have is:
we have a db that i am pulling questionnaires through from into a secondary db (with a web front end). i am pulling them through via LS and adding readers and suthors fields. in the readers/authors fields i am adding a company name that is stored as a group in a secondary NAB.
the issue is that the readers field seems to be being ignored by one form on the web. if i check the document it seems to be right. the readers field is set up properly. as is the authors. ( i checked against the ultimate readers thread on this forum)
the document the form is displaying is a response document.
the rest of the docs in the db work, so security is generally working for the db.
anonymous and default are set to no access
myself and our other dev are both lost as we have seemingly checked everything now.
i did a quick test, i created basic form, added a readers field and gave it myself and other dev as default value. created a form and viewed it in the client - i could see it. i then edited the doc and removed myself as a reader and it vanished in the client. i then viewed on the web and i could see it when logged in as another user.
it seems to be a bug, please help!
thanks!
Subject: :: readers field not working, using secondary NAB ::
“i am adding a company name that is stored as a group in a secondary NAB.”
This is likely your problem, since group lookups will only be resolved from the server’s primary NAB unless you have allowed it. You can allow one and only one external directory to be used for group lookups for security purposes, and I elieve the field in the DirAsst document you need to use is called Group Authorization.
Subject: RE: :: readers field not working, using secondary NAB ::
sorry for delay - have been on another project recently and this website never sends me update emails like i ask for.
thx mate - we were aware of that tho as we have successfully got other areas of this system working.
the issue was a readers field with * as value hidden somewhere. problem was that there were 300+ fields on that form (joy) and i had missed this one.
