Hello,
is there any possibility to access mailbox using iNotes and PDA (without Domono Everywhere).
We have corporate iNotes server with capability to access mailbox from internet kiosk or from desktop computer.
I have iPAQ 2215 with Mobile Windows 2002 and i receive an error message then i attempt to access coprorate iNotes after authorization successfully finished.
Any ideas on that?
Subject: Read mail with iNotes using PDA
John:
There’s been quite a bit of traffic on this forum about iNotes and PocketPC problems.
The bottom line is that the iNotes template is doing stuff (it’s either JavaScript or DHTML and I never recall which) that PocketIE doesn’t like.
There are a couple options, and one which has been discussed here is to create a special “mobile inbox” with no script, no java no nothing. I’ve gotten this to work, but it requires changing the iNotes template … which is always risky.
Another option is to consider Domino Everyplace. DE works, and it’s not all that expensive.
I’d check it out.
Subject: RE: Read mail with iNotes using PDA
In reading up on the Domino Everyplace product, it says that you will need a WAP gateway from a phone service provider. Is this absolutely necessary if all you want to do is read your email (iNotes) in IE on a Windows Mobile PDA using a wireless connection (802.11g, for example)???
On your end, all you need is Domino Everyplace. As noted in a previous response, PocketIE can’t handle the iNotes template directly …
But, if you’re talking about a PDA using 802.11, you still need DE or something similar to serve the pages correctly.
