Read active location doc with script
Hello,I would like to read some values from the user’s active location document with either a Lotus Script or a Java Agent.
Can anybody give me a hint ?
Thanx Martin
Subject: getEnvironmentString
Hi,I think in theorie I know what to do, but it does not function.
This is my code to read the Location variable from the Notes.ini. But I do just get an empty string. What is wrong ? THis is my code:
public void NotesMain() {
	try {
		Session session = getSession();
		AgentContext agentContext = session.getAgentContext();
		String slc = session.getEnvironmentString("Location");
		if (slc == null)
		  System.out.println("No $Location");
		else
		  System.out.println("loc" + slc);
	} catch(Exception e) {
		e.printStackTrace();
Subject: solution
Sorry my fault,I did not realy read the Help. You have to give the parameter true, that Notes does not assume a $ at the begining of the name.
String slc = session.getEnvironmentString(“Location”, true);
