Hello,when upgrading Lotus Notes/Domino from R5 to R6 you have al least two parts of applications/databsases to upgrade:
the “standard” DB’s (i.e. NAB, adminp-DB, users mail DB’s)
additional DB’s (office products, CRM, DMS, self programmed)
While the standard upgrade is not THE big problem and a lot of things are already documented (Notes Upgrade Guide, IBM Redbook, …) and - at least to my personal experience - things work fine…
the application development part is still tricky.
Example:
new functions in R6 (naming problems, other behaviour)
modified Script Libraries in R6 (other internal class structure, so old scripts using “standard” script libraries won’t work or work only partially)
QUESTION:
Is there a upgrade guide from the developers point of view?
a collection of known problems and workarounds
procedures (i.e. first change ODS, then design or vice versa - this might have different results)
upgrade paths
I havn’t found anything really helpful but the “whats new” section in the Designer Help ![]()
There are some upgrade/compatibilty audits available but cover only a small set of problems each (around 30+ … 50 audits).
Any hints would be much appreciated, thanks in advance.
Th. Knecht
